tubing kink
Karl_4
Member Posts: 11
Has anyone had to find a kink in a loop that is already in concrete? I tried the shoving a wire to the kink and using a wiring tracer to find where it stops but the tracer instrument is not precise.
That will be interesting to find
Worst case, xray slab to find. Maybe run temp up a bit if a little flow will go through kink and use IR camera and trace until you find the cool spot which I would think would show up if a little flow goes through. Tim0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
