changing munchkin vision 1 settings
jaydiemme
Member Posts: 13
in Gas Heating
Im going to be adding the vision 1 system to my munchkin contender for the outdoor reset. After reading the manual online it says the changes can only be made by a vision 1 contractor and requires a passcode. Does anybody have experience with this? I havent found any contractors nearby that have knowledge about the system.
Get in touch
with the folks at Heat Transfer Products at the same site you got the instructions and I am sure they will connect you with someone near you that can do this for you.
What is your location?0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
