Gas furnace venting?
Otis
Member Posts: 1
in Gas Heating
I am in the process of buiding a new home and was wondering if it would be safe to run intake and exhaust vent lines under a unexcavated garage. Is it against code? Will the condensate freeze in the exhaust pipe?
Thanks <strong>Brad</strong>
It is not a good idea
especially if you have problems and need to get atthe piping. If you are building you have a lot of flexibility now as to location so make it as short and easily accesible as possible.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
