Distance between tee's
World Plumber
Member Posts: 389
Do I understand right The distance is kept close between tees to keep flow from happening in the other circuit if that pump is off? With Primary/secondary pumping. If I move my tee's far enough away to put in a ball valve and aquastat. Will my worst determent be bleed into the other circuit?
Here's some advice...
I wrote a series of articles addressing this and other piping considerations.
http://contractormag.com/columns/eatherton/alternative_energy_interfaces/
http://contractormag.com/columns/eatherton/alternative_energy_interfaces_2/
http://contractormag.com/columns/eatherton/alternative_energy_interfaces_3/
Don't forget to remove the handle of the tweener ball valve or some newby knowitall will close it for you....
Enjoy!
ME0 -
Typically
You should keep them a maximum of 4 times the pipe diameter apart.
example: 1 1/4 common piping should not exceed 5 inches between tees. Might be just enough room for a valve.0 -
tees
check out a company called webstone they already have a fitting of closely spaced tees with a ball valve already between the tees.0
