Fat Pipe
Roland_18
Member Posts: 147
Hi All,
A while back, there was some discussion about using an insulated water tank in series with a boiler. The aim was to increase the mass of the system and improve efficiency.
I don't remember if it made a difference whether the FAT PIPE was placed on the supply or the return. Does it matter? Why?
Thanks, Roland........
Recall that I am not a professional.
I was thinking about your question of where to place the tank that is there just to increase the thermal mass of the system so as to reduce short cycling. And I was surprised at my conclusion. Which is to put in on the return. I wonder what the professionals will think of this.
Consider: the thermal mass of the boiler must be too low for your application or you would not be doing this. (If the real problem is an oversized boiler, different thinking is required.) Therefore, if you place the tank in the supply, the boiler will heat up quickly, but the heat will not be delivered to the house until the tank is pretty well warmed up, where if it is in the return, the heat will be delivered to the house quickly. Now on the return, the water is not cold, but colder than the supply temperature. This water will heat up the auxiliary tank before returning to the boiler. And since it is cooler than the supply, whatever heat loss there is from the tank will be less because of its lower temperature.
My guess is that if money is no object, I would put a modulating boiler with outdoor reset in there and skip the tank. But money is usually an object, and by Murphy's Law, the existing boiler is too new to replace.
My only experience is with my own boiler in my own house. The boiler is the smallest the manufacturer makes in the mod|con line. If the entire house is calling for heat, the outdoor reset works fine and it does not short-cycle. But the heat load in the upstairs is very low even when it is at design day temperature outside (14F), so on normal days, the load is way under what the boiler can produce even when modulated all the way down. So I might actually benefit from such a tank, if I had a place to put it and the money to pay for it and its installation. But maybe a better solution if I wanted to spend more money would be to double the amount of baseboard in the upstairs instead. This would increase the thermal mass some, get rid of more heat in a given amount of time, and perhaps even permit me to run that zone at a lower temperature and get more condensing.0
- 121.3K All Categories
- 84K THE MAIN WALL
- 2.9K A-C, Heat Pumps & Refrigeration
- 53 Biomass
- 417 Carbon Monoxide Awareness
- 40 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.7K Gas Heating
- 119 Geothermal
- 155 Indoor-Air Quality
- 3K Oil Heating
- 56 Pipe Deterioration
- 772 Plumbing
- 5.4K Radiant Heating
- 362 Solar
- 14K Strictly Steam
- 3K Thermostats and Controls
- 51 Water Quality
- 38 Industry Classes
- 73 Job Opportunities
- 19 Recall Announcements
