Munchkin Boiler
jstracin10
jstracin10 Member Posts: 1
I just bought a house , foreclosure ...has a munchkin boiler I have no idea where to find the part number or anything on the unit...i need it because it appears i am getting an error code 4 flashes on the main board and no spark to the unit....i am smelling gas after it tries to fire 3 times and i can feel the pulser on top kicking on ...not really sure what the issue ...a techinican that was not familar with them said he was thinking outloud and thought main board...but im not so sure...any thoughts? he checked all of the sensors and they showed connective ...but he wasnt sure about the resistance levels.
  • Tim McElwain
    Tim McElwain Member Posts: 4,574
    What is your location?
    The four flash code sounds like an older unit with a board which has since been replaced. It is best to have someone near you who knows Munchkins come and service the unit.
    Try the factory as they may be able to connect you up with someone near you:
    Heat Transfer Products, Inc.
    PO Box 429
    120 Braley Road
    East Freetown, MA 02717
    Telephone:  800 323 9651
    Telephone:  508 763 8071
    Fax:508 763 3769
