FLEXIBLE BOILER VENTING
MRLOU
MRLOU Member Posts: 1
VENTING 7 ULTRA 299 BOILERS USING EXISTING CHIMNEYS AS A CHASE....ONE OF THE CHIMNEYS HAS A JOG IN IT....NEED TO FIND A FLEXIBLE VENTING MATERIAL THAT CAN BE USED FOR CONDENSING BOILERS... ANY SUGGESTIONS, NEEDS TO BE 4"
  • Big Ed_4
    Big Ed_4 Member Posts: 3,556
    Venting
    Venting is so important to do it right . Have you checked with the manufacturer ? Then get it in writing and get the OK with the plumbing inspector ... Sounds like you never called ? Don't deviate from an all ready approved system ... First thought anything flexible could bunch up and create a trap for condensate and you ....
