What are the dangers of buying a used boiler
Hey_Obie
Member Posts: 66
There is a Weil McClain WGTO-4 boiler that is for sale locally asking $700 (includes burner, circular, taco 6 zone valve control with DHW priority). This is the size that I need for my application. The story on the boiler is that it was bought 5 years ago and used for 1 1/2 seasons. An addition was put on and the HVAC guy told the owner that it would cost more to install the baseboards in the new addition than it would to put in a new heat pump.
So the boiler was used for 1 1/2 seasons and has sat for 2-3 years.
What concerns would you have? IWould you pressure test before purchase?
Thanks,
Obie
Thanks,
Obie
Leakage
Besides loosing any warranty ....Check for leakage , plug up all the taps and pressurize the boiler with water to 25# ... Sit and wait to make sure the pressure doesn't not drop ...
Then pray to the boiler Gods for luck and long life ...There was an error rendering this rich post.
warranty
I would ask for a 30 day warranty after it is fired. A hot boiler may leak faster than a sitting cold boiler. HX look clean?Just a guy running some pipes.0 -
Used Boiler
I would def pressure test the iron and make sure no problems. I would also contact Weil with the serial number and make sure this boiler wasn't made during the hinge crack years. You have no warranty. I would purch a new circ and aquastat and make sure that a pro sets up the burner properly. May even replace the burner motor, primary control and cad eye. To be honest the best investment is to purchase a new boiler.There was an error rendering this rich post.
Hinge crack years
Can I assume that the hinge crack had to do with the door? Thanks0
