Manifold & Actuator Question
Kungur
Member Posts: 49
Looking at manifolds and the accessories offered I see that there is an 'Actuator" available. Is this a thermostatically controlled valve that can be used to zone a single loop ,or loops if 2 or more are used together,?
Manifold Actuators
are normally electrically operated (24 volts) by a thermostat. So, to answer your question: yes, they are (indirectly) thermostatically controlled.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 114 Geothermal
