ECM Pumping
NRT_Rob
NRT_Rob Posts: 1,013
anyone know if the "operate in the middle third of the curve" rule holds true for ECM pumps?
Rob Brown
Designer for Rockport Mechanical
in beautiful Rockport Maine.
  • ECM Pumping
    Hi Rob
    Short answer is you can select an ECM pump anywhere between min/max head and 0 to max flow without any large loss in efficiency, unlike a constant speed pump where as you have suggested should be selected in the middle 1/3 of it's flow range (to get close to it's BEP).
    Typically I select ECM pumps to the right hand side but they rarely run there due to us constantly oversizing pumps and systems.
    Hope this helps...
  • NRT_Rob
    nice
    this tech just gets better and better the more I learn about it.
    Rob Brown
  • ECM Pump Selection - Where on the curve?
    Rob, I totally agree - the tech is waaaay cool.  As I say in my training classes, 4 innovations in our industry:
    1)  Electricity
    2) Oxygen Barrier (cross link) pipe
    3) Condensing Boilers
    4) Variable flow ECM pumps
    Drop me a line with your mailing address and I will send our our latest traing CD with ECM app drawings (drawn by Siggy) and lots of other info...
