How abou this the only cause of
Tim McElwain
Carbon Monoxide is GAS?
<ul><li></li><li><a href="http://r.smartbrief.com/resp/vcmwdojnmkzZxfyAamaKyAalHABy?format=standard">Column: Invest in prevention, not detection</a>
<img src="http://www.smartbrief.com/images/briefs2/common/storyicons/icon_opinion.gif" width="49" height="60" alt="" />Rules mandating the installation of a carbon monoxide detector in every home in New York are a colossal waste of time and money, writes Roger Rutter in this opinion article. Instead of spending millions to put carbon monoxide detectors in homes that don't even use gas, officials should establish stricter rules and oversight for the installation and maintenance of gas appliances, Rutter argues. <a href="http://r.smartbrief.com/resp/vcmwdojnmkzZxfyAamaKyAalHABy?format=standard">[u][color=#0000ff]Press & Sun-Bulletin (Binghamton, N.Y.)[/color][/u]</a><span style="color:#666666"> (3/21) </span><img src="http://www.smartbrief.com/images/briefs2/common/sm_share.gif" width="34" height="14" alt="" /><img src="http://www.smartbrief.com/images/shim.gif" width="4" height="4" alt="" /><a href="http://r.smartbrief.com/resp/vcmwdojnmkzZxksYamaKyAalMtqV"><img src="http://www.smartbrief.com/images/briefs2/common/linkedin.gif" width="14" height="14" alt="LinkedIn" /></a><img src="http://www.smartbrief.com/images/shim.gif" width="2" height="2" alt="" /><a href="http://r.smartbrief.com/resp/vcmwdojnmkzZxkvMamaKyAalVwFG"><img src="http://www.smartbrief.com/images/briefs2/common/facebook.gif" width="14" height="14" alt="Facebook" /></a><img src="http://www.smartbrief.com/images/shim.gif" width="2" height="2" alt="" /><a href="http://r.smartbrief.com/resp/vcmwdojnmkzZxkyAamaKyAalfUKF"><img src="http://www.smartbrief.com/images/briefs2/common/twitter.gif" width="14" height="14" alt="Twitter" /></a><img src="http://www.smartbrief.com/images/shim.gif" width="2" height="2" alt="" /><a href="http://r.smartbrief.com/resp/vcmwdojnmkzZxkBoamaKyAalrMXi"><img src="http://www.smartbrief.com/images/briefs2/common/btn_email_story_gray1.gif" width="45" height="14" alt="Email this Story" /></a> </li></ul>
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
