VFD and Scroll compressors
Techman
Member Posts: 2,143
Twomorrow I will be attending a 1/2 day VFD class and a 1/2 day scroll compressor class . I hope it is as interesting as it sounds. Dan H. posted about this a little while ago .
VFD Scrolls
WOW, HOLY MOLY,I'LL BE DAMED,UNBELEAVIABLE.That was two really good classes.The morning was about Variable Frequiency Drive basics for any type of applications ,by Danfoss, and the afternoon was about Danfoss Scroll Compressors and Danfoss Scroll Compressors with VFD incorporated in them . A 3T AC comp @ 60hz will produce 1 1/2 T @ 30hz and 4T @ 90hz along with several compressor protections functions .Another fine class I've gotten myself into Ollie!!!!!!Thanks Dan.H ,RSES and Mr.Ken Fonstad and Mr.Jeff Staub both from Danfoss ,both excellent instructors!!!!!!!!!!!!!!!!!!!!!!0 -
danfos
danfos hs been busy in the vfd compressor field. Go to danfos site and look up turbocor oil less compressor. this is a centrifugal that has no bearings for the rotor it rides in a magnetic field. quiet as can be. we had one of our chillers retro fitted with these compressors and the noise level is unbelivable. so quiet. plus the compressors being on a vfd drive can go from almost nothing to full load with out the problems of running unloaded for a long time.0 -
paul
that sounds cool.What brand of equipment is the compressor in?I will check that out!0 -
turbocor
i believe that mcquay has a partnership deal on some of there models but danfos turbocor can be used as a retrofit on any centrifugal machine. I will post a picture later on today on the conversion0 -
ok
paul, danfoss owns McQuay0 -
turbocor
I did not know that, learn something new every day. Here are some pictures of a conversion. also you can go to youtube and watch one in action. just type turbocor.0
- 87.5K THE MAIN WALL
- 123 Chimneys & Flues
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
