Burnham V-7
spt87
Member Posts: 13
What's the back story with all the V-7 leaks - are they mostly due to improper installs with no return temp protection? Seems a lot of them have trouble near the coil, does avoiding using the coil help (maybe same thing - cold water coming in to the coil causing a shock to the casting).
Or is there really a flaw dooming all of them to a short life? Did later production address the problem or was it primarily early ones that had the problem?
I ask as I have one brand new on the pallet which was made about 2005 and I'm wondering if it is worth bothering with.
Stress Cracks
There is a fault in the design of the casting , causes a stress crack across the clean out area ...
Is it worth it ? Depends on the job I guess ...There was an error rendering this rich post.
v7 flaw
It definatly a design flaw and I think the same thing is happening to the v8, but not as severe.0 -
It will be fine....
so long as you don't overfire it. They uppped the btu ratings to compete w/ the other brands at the time. Fire it a slightly lower rate and it will last a long time.0
- 129 Chimneys & Flues
