Zone valves better on return?
JimX
Member Posts: 12
Are zone valves better on the return than on the supply?
I've found.
No significant difference on any jobs I've done, although I like to keep zone valves on the suction side of the pump to reduce noise on closing. And if you pump on the supply, they'll always be on the return.0 -
suction side
Thank you, I think I will put my new setup that way.
Jim0 -
I prefer the supply side.....
...... if for no other reason than to assure there is no migration flow in the "off" zones. If I were to put them on the return side, I would either use thermal traps or checks on each supply.heatboy
The Radiant Whisperer
"The laws of physics will outweigh the laws of ecomomics every time."0
- 120.1K All Categories
- 83.6K THE MAIN WALL
- 2.8K A-C, Heat Pumps & Refrigeration
- 52 Biomass
- 414 Carbon Monoxide Awareness
- 29 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.6K Gas Heating
- 114 Geothermal
- 151 Indoor-Air Quality
- 2.9K Oil Heating
- 49 Pipe Deterioration
- 734 Plumbing
- 5.2K Radiant Heating
- 355 Solar
- 13.8K Strictly Steam
- 3K Thermostats and Controls
- 50 Water Quality
- 36 Industry Classes
- 69 Job Opportunities
- 14 Recall Announcements
