Equalizer side?
Bob L_3
Member Posts: 15
My question is about your equalizer line. If you had a boiler with 2 risers going into a drop header and your return piping was on the right side of the boiler but you had to go left to the supply piping, could you equalize off the right side or do you have to equalize in this scenario off the left side and pipe back around the boiler to pick the returns up. Basically my question is can you equalize off the opposite direction the steam is headed, when you have multiple risers. If not what are the results if done this way?
equilizer
the equilizer drains water from header so you have to pipe it drop header then take offs to mains then equilizer. If not that way it wont drain water from header. Why not move return.0 -
additionally....
steam and header condensate always need to move in the same direction.1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
Equalizer
Someone either earlier this year or last year was piped the way you are asking about and had BIG problems. The order in the header should be: steam risers from the boiler, steam risers going from the header to the main, and then the equalizer at the end of the header. The header should be sloped towards the equalizer. That way both the steam and the condensate travel in the same direction. If you pipe the equalizer to the other end (before the boiler risers) the steam and condensate streams, flowing in opposite directions, would collide causing big problems.
- Rod0
- 86.8K THE MAIN WALL
- 56 Biomass
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 69 Pipe Deterioration
- 966 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 44 Industry Classes
