WM SGO-7 Rumbling ALOT!
Eric L._2
Member Posts: 94
<span style="font-size:16pt">I have a WM sgo-7 which for the 3 months or so has been rumbling quite a bit. It works fine but its gotten to the point where I can here it running thru the radiator above it on the second floor. It seems that giving it more air helps but then the shutter is open to like 5. Any thoughts?? Thanks
Eric L.</span>
Eric L.</span>
RE: WM SGO-7 Rumbling ALOT!
Could be a number of things has the system beened tuned-up recently?There was an error rendering this rich post.
Rumbling
Yeah I had it tuned up a few months ago. It seems to be lacking air somehow. The rumbling quiets down a lot when I open the chamber viewing port. Any thoughts? Thanks
Eric L.0 -
If it smooth’s out when you open the observation door, it sounds like there’s too much positive pressure over the fire. This could be caused by incorrect firing rate, improper draft adjustment, a blocked flue passage/s or a partially blocked chimney.There was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
