WM SGO-7 Rumbling ALOT!
Eric L._2
Member Posts: 94
<span style="font-size:16pt">I have a WM sgo-7 which for the 3 months or so has been rumbling quite a bit. It works fine but its gotten to the point where I can here it running thru the radiator above it on the second floor. It seems that giving it more air helps but then the shutter is open to like 5. Any thoughts?? Thanks
Eric L.</span>
Eric L.</span>
RE: WM SGO-7 Rumbling ALOT!
Could be a number of things has the system beened tuned-up recently?0 -
Rumbling
Yeah I had it tuned up a few months ago. It seems to be lacking air somehow. The rumbling quiets down a lot when I open the chamber viewing port. Any thoughts? Thanks
Eric L.0 -
If it smooth’s out when you open the observation door, it sounds like there’s too much positive pressure over the fire. This could be caused by incorrect firing rate, improper draft adjustment, a blocked flue passage/s or a partially blocked chimney.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
