Venting
Bruce_06
Member Posts: 2
I have a Weather
King oil fired furnace equipped with a direct vent kit by field
controls. The situation is the secondary safety switch continues to
pop. However there are no signs of poor venting or improper combustion.
I have checked the power supply and the amp draws on the exhaust fan
and all operation is normal. If any one has any ideas anything will
help.
<a href="http://www.heatinghelp.com/forum-reply/1187735/Direct-Venting-Problems">Reply</a>
<a href="http://www.heatinghelp.com/forum-edit-post/1187735/Direct-Venting-Problems">Edit</a>
help.
Have a professional oil
burner technician check it right away. You could be having flue gas spillage back into the room which means the possibility of Carbon Monoxide issues. Do it right away do not hesitate!0
- 62 Biomass
