radiant help
MikeA
Member Posts: 1
I have a two zone radiant manifold four ports on zone one two ports on zone two with thermal actuators for zone control all WIrsbo. The actuators end switch goes into a simple Argo four zone relay w/o priority. The relay turns on circulator for radiant manifold.
Problem is the circulator wont turn on. If you jump the T&T at Argo, pump turns on. All actuators are opening and closing properly. When the actuators are open they complete the circuit and we have conductivity on the end switches. We pulled a new wire from remote manifold about 25 feet connected end switches to T&T same problem. Everything is doing what its suppose to do independently but together it doest work.
This system has been running four years and working properly up until now. I was thinking voltage loss and and maybe adding 24 volt isolation relay but why would the system work fine in years past and this just pop up?
Is that relay a Zone Valve Relay
If your using a zone valve relay the circulator needs to be wired as a system pump. The end switch from the control is wired to TT at the boiler. I believe on an Argo Zone relay there are 2 sets of ends switchs. You should be able to use end switch 2 to power a pump. End switch 1 goes to TT on the boiler. Go to Argo Industries web site. I'm sure there is a manual there."The bitter taste of a poor installation remains much longer than the sweet taste of the lowest price."0
- 120.2K All Categories
- 83.6K THE MAIN WALL
- 2.8K A-C, Heat Pumps & Refrigeration
- 52 Biomass
- 414 Carbon Monoxide Awareness
- 30 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.6K Gas Heating
- 114 Geothermal
- 152 Indoor-Air Quality
- 2.9K Oil Heating
- 49 Pipe Deterioration
- 736 Plumbing
- 5.2K Radiant Heating
- 357 Solar
- 13.8K Strictly Steam
- 3K Thermostats and Controls
- 50 Water Quality
- 36 Industry Classes
- 70 Job Opportunities
- 14 Recall Announcements
