burnham boiler won't start
fz
Member Posts: 1
in Gas Heating
Burnham RV4 boiler, tekmar 362 control, constant speed circ pump, cast iron radiators; 9 years trouble-free operation, boiler wouldn't come on one day this week
-switched off the main 120 v power to the system, waited 10 seconds
-switch power back on, tekmar reset itself
-pump starts, boiler blower stays off
-switched off the main 120 v power to the system, waited 15 minutes
-switch power back on, tekmar reset itself, pump starts, boiler blower starts! system heats up no problem
-same thing happened next day, come home, pump is running, no boiler ... after power-off/15 minute wait/power on, system runs good for 2 days
-same thing today, except can't get the boiler blower to start-up, pump runs no problem
any suggestions would be appreciated
When the blower is off
and not running with the circulator running, do you have power to the blower? If yes then the blower is bad and needs replaced. However if you have no power then go back to the Tekmar control and see if you have power, if not then the Tekmar is faulty.
It is a good idea however to have a professional take a look at the system.0
- 120.1K All Categories
- 83.6K THE MAIN WALL
- 2.8K A-C, Heat Pumps & Refrigeration
- 52 Biomass
- 414 Carbon Monoxide Awareness
- 29 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.6K Gas Heating
- 114 Geothermal
- 151 Indoor-Air Quality
- 2.9K Oil Heating
- 49 Pipe Deterioration
- 734 Plumbing
- 5.2K Radiant Heating
- 355 Solar
- 13.8K Strictly Steam
- 3K Thermostats and Controls
- 50 Water Quality
- 37 Industry Classes
- 69 Job Opportunities
- 14 Recall Announcements
