Pennco 1605HSD pilot won't stay lit
reedvalve
Member Posts: 1
in Gas Heating
Hey-
I just found this great forum after searching around google for some gas fired steam boiler info.
Following the lighting instructions on the side of the unit, I tried a few times to get the pilot lit (it went out a few hrs ago). At first it wouldn't stay lit after letting go of the red button. Once it did stay lit for a minute but then went out. The last time it stayed lit and I got the boiler to fire, but it went out a minute later.
I'm going to call for service tomorrow but I'd like to know what the problem might be so that I don't get ripped off (hopefully the company & tech will be honest). I've been meaning to do the right thing and have a pre-winter check done anyway. Fortunately its not freezing yet.
Thanks in advance
-Ethan
Thanks in advance
-Ethan
Probably needs a new
thermocouple and the pilot will need cleaned. Check Hot Tech Topics "Procedures for Troubleshooting Thermocouples" so you do not get ripped off. A good tech will follow those procedures and take some millivolt readings.0
- 120.1K All Categories
- 83.6K THE MAIN WALL
- 2.8K A-C, Heat Pumps & Refrigeration
- 52 Biomass
- 414 Carbon Monoxide Awareness
- 29 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.6K Gas Heating
- 114 Geothermal
- 151 Indoor-Air Quality
- 2.9K Oil Heating
- 49 Pipe Deterioration
- 734 Plumbing
- 5.2K Radiant Heating
- 355 Solar
- 13.8K Strictly Steam
- 3K Thermostats and Controls
- 50 Water Quality
- 37 Industry Classes
- 69 Job Opportunities
- 14 Recall Announcements
