Furnace Won't Ignite
fishy
Member Posts: 1
in Gas Heating
My GMP furnace is a 1996. It has a electric ignition pilot light that won'tignite.The blower motor comes on but no ignition.
The drain hose had come loose several months ago and I saw water had dripped down on some of the connectors and parts.i don't think the water got to the motherboard. I cleaned all the connectors and got the blower motor to turn on but no iignition.
Now what????
R taylor
Now what????
R taylor
If you have power to the board
120 VAC and 24 VAC and it will not give you any spark the board is gone and will have to be replaced. What is the Make and numbers on the board?0
- 167 Indoor-Air Quality
