HyTech Boiler Part Needed
PAE
Member Posts: 1
I have 2 Hy Tech Boilers that heat my house. I have been searching for a part for one of them for 9 months or more to no avail. The particulars of the boiler is as follows:
Serial # 86-28330
Model # HT-8ANE
The part I need is called HT-8/14 Water Diaphragm Valve "O" ring replacement kit. (ASP507).
The problem is that no one seems to be able to find this little part, and I am running out of time to get it fixed and running by cold weather. I was told that if anyone could help me, you were the one who has the most knowledge, and may know where to find the part or fix the problem. Both units work very well, and I hate to replace one for the lack of this small part. Any ideas? The place I last got the part in Colorado doesn't carry them anymore, and the boys in New Jersey I was referred to also don't have the part.
Help! What to do now? Any ideas would be very much appreciated!
Serial # 86-28330
Model # HT-8ANE
Huh,,,,,
I think HyTech is gone,,,, the only thing I could find was Paloma and if you can read Japanese you may find what your looking for.
"O" rings can be ordered about anywhere, if you know the original size,,,,, if not you are likely @outta-luck!0 -
Try R.L. Gourley
80 Felton Street, Waltham, MA 02254
Phone 781-894-45630
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
