Non 02 barrier tubing
digger_2
Member Posts: 39
My home has 2800 ft of 1/2" non 02 barrier tubing In a "Maxxon Thermafloor Underlayment" pour that is 1 1/4" thick. I want to redesign the system to get better control. Current tax credits and utility rebates could cover alot of the expense. The problem is the (in my opinion) the destrutive nature of this tubing. I have had "bronze" pump failures in the past. I lost two B&G LR15B pumps over 4 seasons. (The current PL30B pump has held up longer but it is loud and oversized.) I would appreciate input on how best to work with this tubing.
BTW The tubing is arrayed in three zones (fourteen 200' loops) in a 1400 sq ft home. It has been heated with a 50 gallon gas water heater since it was installed in 1999.
I procrastinated on this project because I felt I could buy alot of gas with the price difference between a 50 gallon gas water heater and the system I always wanted.
Separate the tubing
with a properly sized stainless flat plate exchanger and use a stainless pump on the tube side.0 -
I need to decide what zone and PD valves to use. I worry about the possibly ferrous valve stems being corroded like the pump shafts on my failed B&G LR-15B bronze pumps that were imstalled originally. Both failed after only two seasons. I will use some form of treatment going forward.0 -
Does anyone know ...
Does anyone know if a Spriovent or a Taco 4900 series air eliminator could remove the dissolved air faster than it leaks through the tubing?0 -
I would think any properly installed separator would work. This homemade separator (see attachment) has worked on my system for 10 yrs. It is definitely not a technological masterpiece.0
- 121.3K All Categories
- 84K THE MAIN WALL
- 2.9K A-C, Heat Pumps & Refrigeration
- 53 Biomass
- 417 Carbon Monoxide Awareness
- 40 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.7K Gas Heating
- 119 Geothermal
- 155 Indoor-Air Quality
- 3K Oil Heating
- 56 Pipe Deterioration
- 768 Plumbing
- 5.4K Radiant Heating
- 362 Solar
- 14K Strictly Steam
- 3K Thermostats and Controls
- 51 Water Quality
- 38 Industry Classes
- 73 Job Opportunities
