Alternatives to threaded pipe unions
JN
Member Posts: 28
Hello,
It looks like years ago someone cut the feed to the attic radiator. We will be finishing the space and I'd like to heat it ;) They capped the tee on the main line, but cut the pipe that goes to the attic. The pipe is walled into a pipe run up the side of the house. I can get at it, though its surrounded by other pipes like sewage and water that have been added over the years. I can get in there to cut it but not to thread it.
Since I cant get in there to thread it are there any other sort of union options so I can ge this pipe to where it needs to go?
Thanks!
josh
Thanks!
josh
threading hidden pipe
can the pipe be moved up and down, to give clearance for threading? there are hand threaders available cheaply at harbor freight, or rentable. generally i don't like cheap tools, but in this case, you will never want to hand thread a pipe again! alternatively, the old pipe could be removed in sections, and replaced by a series of 6 ft. nipples, joined by couplings--nbc0 -
If you have access to a welder
you could weld a flange on it, then continue the pipe with a threaded flange. Have someone standing by with a fire extinguisher if you go this route.
Make sure the pipe didn't get cut off somewhere in the wall!All Steamed Up, Inc.
Consulting0 -
im in luck
I found a coupling in the wall that i can get a wrench on!0 -
Great!
let us know how you make out.All Steamed Up, Inc.
Consulting0
- 120 Geothermal
- 394 Solar
