Grundfos Handbook
heatguy
Member Posts: 102
the second edition is a great booklet the first was a little weak
Grundfos Handbook
I recently received a rally nice "Grundfos Handbook". You all would like it. Try www.grundfos.us/handbook and see if you can sign up for it. It is a 98 pg, 4x6 piece with a ton of good info.0 -
Grundfos book
Waiting for mine to arrive, how long did it take for you to receive it?0 -
It's good. but
the negativity towards zone valves is a bit of a turn-off.I know they're selling pumps.......0 -
That surprises you?
I can't imagine zone valve manufacturer's pushing pumps or furnace manufacturer's pushing boilers. It's a guide for their products. My surprise is that you're surprised. I only wished they mentioned WILO, now that would have been fun. They sell pumps...0 -
But
they're also selling ECM pumps,do they think multiple ECM pumps will go on very many residential jobs? I'm not surprised,it just ticks me off when they call a sales pitch education0 -
Synergy
I can imagine zone valve manufacturers pushing "a" pump; to boost sales, don'tcha know.
Jed0 -
Its about energy savings
the book is about energy savings.
if you use an ecm pump (they wont mention Wilo the same way taco doesn't mention Grundfos) it will save energy.
using zones valves, great! using radiant-great! because the pump self adjusts to the zones/thermal actuators opening/closing resulting in no need for by pass, etc.
Zoneing with Circs? Expensive out of the gate but when you compare a conventional pump at 87watts v. an ecm pump at 15watts it makes you think.
especially since 70 % of your customers are probably running around changing their light bulbs from 100/60/40 watts to the cfc's that use 10/8/6 watts.
Save energy. Use the ALPHA0 -
What is the promo code?0 -
Todd
if in USA use 18120
canada 481200 -
I`m interested,
but it`s a different link if in Canada.
Probably get looked-into as fast as anything Heat-Link does.
Some outfits seem so independent they have no-need for us "little guys".
Dave0 -
code
I typed in my zip code and it said i was good to go, if I dont receive the book Ill try the code that Rick mentioned0
- 87.8K THE MAIN WALL
- 131 Chimneys & Flues
