shocking thermostat
whenever i make a change to my visionpro thermostat, my static electricity disharges into the 'stat. are there any conventional ways to handle this? i don't want the static discharge to fry the electronics inside it. unfortunately, this location has very staticey carpet.--nbc
    Jamie Hall Member Posts: 25,763
    is there any way
    you can touch almost anything metal in the house just before (and preferably hold onto while) you touch the thermostat? Almost anything will do -- a light fixture, radiator... it doesn't take much.
    I can think of more exotic approaches, but... they aren't that simple.
  • Jim_64
    Jim_64 Member Posts: 253
    yeah,
    wear a static discharge wrist strap
  • Tony_23
    Tony_23 Member Posts: 1,033
    I thought this thread was going to be about a thermostat advertisement :)
    Now really, you need a humidifier.
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,577
    static discharge
    of course that's what i do now-just thought there might be some more technical way.--nbc
  • bob young
    bob young Member Posts: 2,177
    wear gloves
    or better yet.... tell your wife to adjust it ! lol
  • ttekushan_3
    ttekushan_3 Member Posts: 963
    Two options come to mind.
    One is a fine ground wire attached to a suitable ground, preferably through a 1/2 meg to 1 megaohm resistor, to suppress the "snap" part of the arc. Bring the wire up along a molding or some such thing so you can touch it with, say, the edge of your hand.
    The fool proof alternative:
    Terry T
    steam; proportioned minitube; trapless; jet pump return; vac vent. New Yorker CGS30C
    someone's learning HTML!
    good idea, i will get a nice brass plate, and ground it through the unused conductor in the cable, and place it behind the thermostat, so i can touch it before the 'stat.
    why don't the manufacturers produce more affordable wireless models? running the signal through the house wiring, like the old radio-shack "plug-in" intercom would be an option too!
    you did a good job of incorporating the J-PEG file in the posting!--nbc
  • ttekushan_3
    image is low res and
    small enough I figured it wouldn't cause anybody any trouble. Besides, the basic sight gag was the first thing that came to mind. Paraphrasing a past U.S. vice president, its a terrible thing to have lost one's mind. ;-)
    Terry T
