Hydrostatic Pressure
Can someone tell me what hydrostatic pressure would be exerted on the walls of a tank per foot of water height?
Thanks, Bob Gagnon
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=331&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • bob_46
    bob_46 Member Posts: 813
    2.31 psi
  • bob
    Be careful here ;-),
    1 PSI pressure will push water up vertically 2.31 feet.
    Dave
  • bob_46
    Duh
    I should have said 1/2.31. Thanks Dave.
  • scrook_2
    scrook_2 Member Posts: 610
    but
    The hydrostatic pressure of the water an any point is the same regardless of directon, otherwise the water would flow from higher pressure to lower within the tank.
    A tank with say 46.2' of water in it will, at a point 23.1 ft below the surface, see 10 psi of pressure on its wall; at the bottom (46.2' from the surface) 20 psi, at the top (0') 0 psi. etc.
    1 psi only pushes the horizontal surface of the water vertically, if the vessel walls are not vertical the water also moves horizontally until it touches the walls!
  • Ron Gillen
    Ron Gillen Member Posts: 124
    On it's base
    .433 PSI/foot of water on the base. Less as you move up the walls.
  • The Boiler Dr.
    The Boiler Dr. Member Posts: 163
    Wouldn't hydrostic pressure
    also be determined by the size of the vessel - height and width - multiplied by the weight of the liquid
  • hydrostic pressure
    Width wouldn`t matter, only the height.
    Depending on your sea-level of course ;-).
    A divers depth gauge is the same on both sides of a lake.
    Dave
  • The Boiler Dr.
    What I was referring to
    was that depending on the volume (cu ft/in)of the vessel the weight of the fluid would generate a greater hydrostatic pressure ... not?
  • Not really,
    speaking of water here,, it`s the added pressure we put on top of it that will add to the hydrostatic pressure below.
    Dave
  • jp_2
    jp_2 Member Posts: 1,935
    think at extremes
    sometime helps.
    if a pool were 1 inch high and 1 inch wide, think of pressure against the wall.
    now make that pool 1 inch high and a mile wide, pressure at bottom of both pools the same.
    if you stood in both pools, does it make sense that you could feel different pressures on your feet?
  • Hydrostatic Pressure
    Is that the pressure of water not moving. I am dealing with the local hydro plant operators and the height of the river above the height of the partially blocked intake pipes. Wouldn't that be fluid pressure because the water is moving? That may be harder to figure with flows and all, but if it were not moving a two foot difference in height would exert 4.62 psi on the sides of a vessel?
    Thanks, Bob Gagnon
    Jamie Hall Member Posts: 26,835
    Hydrostatic pressure
    is determined solely by the density of the fluid and the height of the fluid above the point.
    Now... if the fluid is moving, interesting things happen, and it can get really complicated. However, if the fluid is moving at a constant velocity, the pressure is the hydrostatic pressure. If you change the velocity, however, that's when it gets interesting. In open channel flow, say a steeper or shallower channel, or in full pipe flow, a larger or smaller diameter pipe, the static pressure will change to keep the total energy of the moving fluid constant. In open channel flow this shows up as a change in the depth of the water, for instance. Another way to change the velocity is to change the direction of flow without change the speed. Then a considerable pressure is found in the area where the direction of flow is changing -- say at a bend in a river, or in an elbow on a pipe. This pressure comes about because a force is required on the fluid to make it change direction (a change in momentum requires a force operating over time).
    Can get messy...
