Removing radiators, too much pressure?
Jamie Hall
Member Posts: 26,841
won't be a problem. That's controlled by the pressure controller on the boiler. What may be a problem is that the boiler will be wildly oversized for the remaining radiators, and will cycle on pressure more often than you would like -- and may lose efficiency. But there shouldn't be any danger as such.
Removing radiators/too much pressure?
Hello,
I have a 115 year old house with 16, 1 pipe radiators (steam). We are planning extensive renovation and a new addition and while we do so, I am wondering if I can disconnect about 10 of them and cap the pipe and still have heat in the remaining 6. Will there be too much pressure? Is having a boiler sized for 16 units, too dangerous to operate with only 6 connected? Any precautions I should take?
Thank you for any advise you could give me
Marc0 -
disconnect & run system
ONLY problem is valves may not hold tight & you cannot cap them because valve has union machine thread. remedy : remove old valve & install new ones. if by chance they do hold tight , you luck out. system can be run safely with no problem0
