steam boiler water meter
r. perry
Member Posts: 45
Anyone know where to look/buy/who sells a water meter for a steam boiler? I've checked/asked at all the local plumbing supply houses in my area and nobody has heard of just a water meter. All they have are water meters that are part of an automatic water feed system, but no stand alone water meters. Nothing on Pex Supply.com ethier.. ant ideas??
The automatic feed has a built in water meter. I will look into the exact model we use. This is only for the feed water.Cost is what you spend , value is what you get.
cell # 413-841-6726
meter
Try water-meters.com, it looks like you can buy right from their website, if not try to Google Neptune Water Meters, and you can search0 -
Steam or condensate meters
A company called Cadillac meters makes meters for the condensate side of things. We install them on waste steam systems0 -
if,
What you are looking for is a meter to tell how much make up you are using any decent plumbing supply house would have them. be sure and read the directions before installing, you wouldnt believe how many Ive seen improperly installed. Try here for both water and condensate meters:
http://www.statesupply.com/displayCategory.do?cuid=FP_PS_Water_Meters0
