M1 Miller
Bob Forand
Bob Forand Member Posts: 305
I went on a call tonight for a Miller M1 furnace, it turns out that the vent on the roof was covered with snow. But after I got the furnace operating, I looked in the view port and noticed a round shaped impingment area on the back of the hx. Does anyone know how to actually test the M1 heat exchanger ? My fear is the only way is to pull the furnace and tear down the furnace.
  • Todd_35
    Todd_35 Member Posts: 1
    You will see impingment area on every Miller M1. There is no need to tear the furnace down.
  • JOE_104
    JOE_104 Member Posts: 15
    the fresh air in take was cover with snow.the burner couldn't pull in air for combustion & snuff its self out.the back of the m-1 chamber bumps out a bit.it what holds the chamber in place.need to pulled burner & chamber to inspect hx.be sure to have replacement gaskets available
Welcome
It looks like you're new here. Sign in or register to get started.
