Boiler flooding
ed wallace
Member Posts: 1,612
boiler does not have a high water cut off the lwco float has hung up and is telling the auto water feed the boiler is low on water you need the boiler serviced now could have been worse lwco could have failed and you would be buying a new boiler
boiler flooding
I returned to my new home after 3 weeks away and the basement around the boiler (single pipe steam system) was flooded. The boiler was taking on water and releasing it from a pipe onto the floor of the basement right in front of my eyes. I know that I am supposed to flush water out of the system every week, but I thought this mostly to get rid of mucky water. I also know the boiler has a low-water cutoff. Does it not have a high-water cutoff too? Is it supposed to just keep taking water even if it doesn't need it? Or do I have something broken in my system?0 -
make sure it doesn't start coming out of the first floor vents
- 86.8K THE MAIN WALL
- 56 Biomass
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 69 Pipe Deterioration
- 966 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 44 Industry Classes
