A work in progress.
singh
Member Posts: 866
two Triangle Tube Solo 175's.
So far, job has 33 panel rads installed, and two Smart 120's.
Eventually, this old house is being converted into a B&B. But a lot of work needs to be done like replace orginal slate roof, upgrade electrical screw in fuse panel to new panel. Replace all the wiring, all the galvanized plumbing water lines, and more..
Owners are now on a budget, after trying to accomplish everything at once and money disappearing rather quickly, not to mention they wanted everything, but no planning.
As far as the heating goes, there will eventually be panel rads, HWBB, and radiant zones, and Mr.Slim units. Boilers controlled via a Tekmar265 and panel rads on constant circulation using a Tekmar 508 with sensor.
Supposedly, now , an outdoor wood boiler wants to be added, I just wish I knew before hand, any way not too bad a job.
Also, a special thanks to Darin Cook, who helped out a few days over the summer getting the Smart tanks down in the basement and running the exhaust piping from boilers.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=377&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
- 117.3K All Categories
- 82.7K THE MAIN WALL
- 2.7K A-C, Heat Pumps & Refrigeration
- 43 Biomass
- 400 Carbon Monoxide Awareness
- 7 Chimneys & Flues
- 1.6K Domestic Hot Water
- 4.3K Gas Heating
- 106 Geothermal
- 148 Indoor-Air Quality
- 2.7K Oil Heating
- 45 Pipe Deterioration
- 675 Plumbing
- 4.8K Radiant Heating
- 353 Solar
- 13.2K Strictly Steam
- 2.9K Thermostats and Controls
- 47 Water Quality
- 31 Industry Classes
- 64 Job Opportunities
- 11 Recall Announcements
