best/cheapest way to heat basement apartment off hydro gravity
Robert O'Brien
Member Posts: 3,450
Low cost now or in 10 years?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=313&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
basement heat job
I need to put heat into the basement of an old victorian home in watertown, mass. The boiler is oil-fired water serving radiators throughout house. Basement needs heat in two separate rooms adjacent to mechanical room. what is the best/ most economical way to heat? There is one 3" supply main off the boiler, with an 1 1/4" return line in the back hartford loop style. Is the best bet to put a 3x1 tee right off the supply with a pump and flowcheck to two different radiators or should I go with baseboard? The emphasis from customer is low cost. Thanks for all input!0
- 117.5K All Categories
- 82.8K THE MAIN WALL
- 2.7K A-C, Heat Pumps & Refrigeration
- 43 Biomass
- 402 Carbon Monoxide Awareness
- 8 Chimneys & Flues
- 1.6K Domestic Hot Water
- 4.3K Gas Heating
- 107 Geothermal
- 148 Indoor-Air Quality
- 2.7K Oil Heating
- 45 Pipe Deterioration
- 679 Plumbing
- 4.8K Radiant Heating
- 353 Solar
- 13.3K Strictly Steam
- 2.9K Thermostats and Controls
- 48 Water Quality
- 31 Industry Classes
- 65 Job Opportunities
- 11 Recall Announcements
