best/cheapest way to heat basement apartment off hydro gravity
Robert O'Brien
Member Posts: 3,541
Low cost now or in 10 years?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=313&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
basement heat job
I need to put heat into the basement of an old victorian home in watertown, mass. The boiler is oil-fired water serving radiators throughout house. Basement needs heat in two separate rooms adjacent to mechanical room. what is the best/ most economical way to heat? There is one 3" supply main off the boiler, with an 1 1/4" return line in the back hartford loop style. Is the best bet to put a 3x1 tee right off the supply with a pump and flowcheck to two different radiators or should I go with baseboard? The emphasis from customer is low cost. Thanks for all input!0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
