unpleasant smell associated w/ steam heat in one specific room
Andy Smyth
Member Posts: 8
THANK YOU !!!! Larry. That ancient radiator was filthy w/ grime, dirt, kitchen produced residues, and dust. I cleaned it w/ tcp solution and got rid of an old cover made from a dense fiber board that was either part of the problem or absorbed that smell also. With that gone and radiator somewhat cleaned there is a huge improvement. I'm going to do one more super thorough cleaning to clinch it!
smell associated with 1928 2 pipe steam heat system
Chicago area 30 unit building built in 1928. My unit has 5 2pipe steam radiators and (only) the kitchen radiator seems to produce an unpleasant odor. Another odd thing is 4 of the five radiators (all located on outside walls) get what appears to be plaster dust eminating up out of the walls and onto to the wood floors under or right near these radiators during the winter season. Does anyone know what either of these problems might be?0 -
Kitchen radiator smell.
I would suspect something that was spilled or sprayed on the radiator or adjacent wall. Have you tried thoroughly cleaning the radiator? Was the radiator recently painted? It is possible that the offending substance was painted over in an attempt to seal the smell in.
If you can describe the smell, perhaps someone will know of a substance to neutralize the smell.
Larry C0
