Steam Mains – How many do I need?
Oakvu
Oakvu Member Posts: 26
I live in a 110 year old home with a one-pipe steam system. I have 3 mains running from the boiler. The original main runs 10’x 25’x 15’x 25’ and feeds 6 radiators (4 1st floor & 2 2nd floor). The 2nd main runs 18’ and feeds 4 radiators (2 1st floor & 2 2nd floor). The 3rd main only runs about 5’ from the boiler before splitting to feed 2 radiators (1 1st floor & 1 – 2nd floor).
The original & 2nd mains have Main Vents at the end on T’s.
It usually takes about 25 minutes to have heat in all the radiators on a cold start. The Main Vents were replaced last year.
Can I increase the efficiency of the system by adding more Main Vents? Do I add them at the ends/turns on the original mains to get the steam to move faster thru the system?
It takes the original main the longest to heat.
The system is a good balance, but it seems I should be able to get the steam to the radiators faster.
Thanks.
