Ultra-Finn vs staple up
Jim_109
Jim_109 Member Posts: 45
What effect does heat loss have on Ultra-Finn vs staple up at the same floor temperature? rdtps70@hotmail.com
  • Kevin_in_Denver_2
    Kevin_in_Denver_2 Member Posts: 588
    Ultra-Fin can supply more heat to a given room, but it would mean a higher floor temperature.
  • jp_2
    jp_2 Member Posts: 1,935
    R U sure about that?
    ultra fin work on convection, staple up with heavy plates works by good old conduction.
    hot_rod Member Posts: 26,476
    define \"staple up\"
    I prefer UF to bare tube stapled against the floor. If that is how you define staple up.
    UF work nice if you are adding to a HW baseboard system, no temperature mixing required.
    Best method, for retro fit would be the extruded transfer plates, with a mixed down temperature. Usually 100- 120 will work with transfer plates.
    hr
