home hot-water radiator valve repacking/refurbishing
tim smith
Also I am sure in your neck of the woods there would be a plating company to re plate. I have had regular cast bronze valves nickel plated and wow are they nice. Tim
hot water radiator valves
I'm looking for a professional firm (U.S.) to repack and refurbish hot water radiator valves - early 1920's Honeywell continuous circulating valves. They definitely need "repacking" and a bit of clean-up. Keeping the original valves is important for maintaining aesthetics and originality in our 1920's Georgian Colonial home. Please email ASAP!!!!!0 -
I'll bet that is a pretty standard packing bushing in there, just inside the top nut under the handle. You can likely add some string packing to make them stop leaking and turn them a couple times a year to exercise them. My local supplier is online at
http://www.m-onespecialties.com/default.asp
Tim
Just a guy running some pipes.0 -
Packing
Nothing special about those valves as far as packing goes. Remove the gland nut and follower, and measure the existing packing that you take out for a replacement. A good teflon packing will last another lifetime in there. Also, your local Plumber should be able to do the work.0 -
Radiator Valves
I have the same type of circulating hot-water radiator valves as you do. I have three radiators now with this problem. Local plumbers have been of no help so far. Have you found anyone to do a repair or replacement of your radiator valves?
Thank you,
Lee Graves0 -
You should post your
location, or look under "Find a Pro" on this web site.
Thanks, Bob Gagnon
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"To learn more about this professional, click here to visit their ad in Find A Contractor.0
- 87.8K THE MAIN WALL
- 131 Chimneys & Flues
