\"Singing\" steam trap
gerry gill
Member Posts: 3,083
or perhaps to much boiler pressure??
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=360&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
gwgillplumbingandheating.com
I replaced.....
an ancient 1/2" Dunham 1E radiator trap with a Mepco 1E a couple of weeks ago.
Now the tenant says it makes a high pitch squealing sound on occasion. As luck would have it, it is right next to his bed.
I haven't been there to check it yet, but what could make a trap sing?
Any thoughts,
JimThere was an error rendering this rich post.
I'll check....
it out today. Funny, it did not do that when I was there. I waited until the rad got hot all the way across and the trap closed.
It's in an old commercial building that runs at 5 psi.
Maybe some junk loosened the rad and lodged in the trap.
Thanks,
Say Jim,
5 psi sounds pretty high,, does it have to run there?
Dave0 -
I tried....
turning it down once, as soon as it falls below about 4 psi they get no heat to the fifth floor.
This is an old commercial building in which the top three floors have been converted to crappy apartments.
I believe at one time it was a vacuum system, but the vacuum pump is long gone. As long as the tenents aren't complaining, the owner isn't interested in fixing it.
