Sizing Boiler for Indirect
Rob Blair
Member Posts: 227
Okay, here we go again. Sizing up a house, 78K heatloss, and I want to install a 60 gallon indirect. All electric boiler. House is Polysteel so it is like a fridgerator. Planning on using a SMart 60 tank and an Electro boiler.
Thoughts?
Thanks,
Rob
Thoughts?
Thanks,
Rob
An electric wh
would be less expensive and more efficient as the electric goes right to the DHW without the loss of the piping, pumping and HX with the indirect.
Depending on their DHW needs an 82 gallon tank can furnish most large households. Plenty of 50 gallon tanks in my area for average users.
hrBob "hot rod" Rohr
Living the hydronic dream0 -
Thanks HR.
Didn't someone just post about trying to uncomplicate things.
Thanks,
Rob0 -
simplier yet
if you have the service capacity, go on-demand electric and rid yourself of the losses from that 60 gal heat radiator.
add a little solar preheat and now you're greening.0 -
Never size up the boiler for indirect on residential,size up the tank instead. Kills boiler eff when you size up.0 -
It's an electric boiler
It may short cycle the relays inside it, but the efficiency won't change.
I like the separate electric water heater tank.
Noel0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 970 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
