can anyone reccomend a steam prof. in th lunenburg, Ma. area
Ray Landry_2
Member Posts: 114
Brian, I sent you an email.
I need a professional that knows steam heat in the Lunenburg, ma area0 -
Steam professional
Are you looking for a contractor or an engineer?0 -
what seems to be the problem??
Some of these things can be worked out without too much trouble by lurking here on the wall, and posting a well phrased question or two...
To answer your question, I have had pretty good luck with Peoples Fuel out of Gardner. They installed a new MegaSteamer for me this past fall and did a nice job. If you have read Dan's books and have an understanding of some of the basics you will do better with interviewing contractors to find a competent pro.0 -
Don't use
I used to live there and used to work in that area. I can't really recommend anyone but I can say stay away from the plumbing insp if it is still the guy who took over from his father. His steam piping and oil work leave a lot to be desired.
Seen his work.0 -
thanks to all who replied
thank you all for your help. I called leominster plumbing and heating, and the problem ended being the small hot water extender tempering valve 70a. the service tech was really helpful he said that he thought that upon install. that the installers didn't remove the guts from the valve before swetting the joints. A 5 minute kit solved the problem. thanks again. Brian0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 970 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
