Wind chills below zero and temps in single digits a problem
Steve Garson_2
Member Posts: 712
Also: reduce the venting in the room with the thermostat, if one thermostat controls the whole building.
Steve from Denver, CO
Below zero wind chills and single digit temps causing problems
The one-pipe steam radiators, furthermost from the boiler, in each of the two lower apartments of a 4-Plex are not heating more than a third of their columns and with high wind chills and low temps I have some unhappy residents. The radiators in question are 22" high and 18 columns across. The remainder of the radiators in these two lower apartments are heating all columns. Suggestions welcome.0 -
unhappy residents
is no fun at all! Check the vents on the radiators that aren't heating all the way across would be my first thought.Br. Jamie, osb
Insulate...
Insulate, insulate, insulate. The house....the pipes and the space the pipes run in. Nothing makes steam collapse faster than cold, and the long runs aren't being satisfied while the close ones are and I'd bet...satisfying the thermostat.
Another option is steam TRV's for each radiator. Pricey and trying to train tenants on the use and function sometimes becomes a chore. Best of luck, but get the pipes as insulated as you can. Chris0
