AC Filters for HV System
Mark_46
Member Posts: 312
Sorry, I don't have an answer for you. But I am running Hi-V as well and have the same question about filters.
Filters--where?
I love this page, I found it for help with the steam system we recently acquired, but then I also saw trhe A/C section.
We have a new H/V 5 ton A/C install. Is there abetter source of filters other than from my installer? All I have been able to find so far is 4-Pack of True Blue Pleated fron Home Depot by special order. They say these can last longer (up to 3 months) than the 1 month fiberfills my AC company has, and also do better for allergens, but my AC compnay warns that these could get constriced and cause problems for the air flow. My needed size is 14" x 36" x 1".
Anyone have any suggestions as to where else I can look, or advise that I should not get these?
Thanks.0 -
Be careful w/ those filters. they take out more particulates but HV systems are VERY touchy when it comes to air flow.
I would use the fibreglass filters and change it every 2 wks.0 -
Filter source
IAQSOURCE.COM
I use the 3M allergen filters.0 -
Filters
Hi! Filters! I sell "pleated filters" because they do catch more particles then those see-through filters. ANY HV system can use better filters because the return duct should be size correctly to begin with .The more caught in the filter is less dirt being resirculated,less dirt on the evap coil and less dirt plugging up the condensate drain.And then there are electronic air cleaners!Enjoy!0
