Zone line thermowells
Brad White
Member Posts: 2,399
Go up one pipe size. My ideal location is in a tee at a bend such that the stem points into the flow and the leaving flow goes out the branch. Good turbulence around the bulb too.
-Ernie White, my Dad
I am going to be installing solder type thermowells in my zone return lines for thermometers, and am concerned that the probe intrusion into the T's might have an ill effect on circulation. I was unable to find this addressed anywhere in the archives. Are my concerns unfounded?
Jon L.0 -
Thermwells
Instead of a tee I use a cross,very expensive, as compared to a same size tee but the restriction is less.0 -
Thermowell
Thank you for the input. The step up in size seems to be just the ticket for us. Thanks again.
Jon0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 161 Indoor-Air Quality
- 70 Pipe Deterioration
- 995 Plumbing
- 6.3K Radiant Heating
- 391 Solar
- 15.4K Strictly Steam
- 55 Water Quality
- 44 Industry Classes
- 48 Job Opportunities
