boiler or water heater for 1200' addition plus 840' garage?
Robert A
Member Posts: 1
I'm getting mixed recomendations. Do I use a boiler or a water heater as a heat source? I am adding a 1200' addition, with basement that will have a shop room and family room and a small bathroom and some storage, and an 840' garage. also we would like to have a little heat in 25' of sidewalk on the north of the house and some heat in the approach to the two garage doors. I'm told water heaters stack/layer the heat (bad) and boilers temp can't be turned down because the chamber is too cool to get rid of the moisture and will rust out too soon. any suggestions? THANKS, Robert
Boiler
A boiler would be recommended. There are various modulating-condensing appliances available that can handle multiple loads. A pro should do the heatloss and system design to make sure the appliance is sized correctly for the various loads.
Boiler
I second Paul's recommendation. A small mod/con would be appropriate.0
- 120.9K All Categories
- 83.8K THE MAIN WALL
- 2.8K A-C, Heat Pumps & Refrigeration
- 53 Biomass
- 415 Carbon Monoxide Awareness
- 34 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.7K Gas Heating
- 114 Geothermal
- 154 Indoor-Air Quality
- 2.9K Oil Heating
- 49 Pipe Deterioration
- 745 Plumbing
- 5.3K Radiant Heating
- 358 Solar
- 13.9K Strictly Steam
- 3K Thermostats and Controls
- 50 Water Quality
- 37 Industry Classes
- 71 Job Opportunities
- 14 Recall Announcements
