Waste Vegetable Oil in a beckett AFG Burner
Brad White
Member Posts: 2,399
would these cars be clogging the Nations arteries?
Pass the salt.
Brad
Pass the salt.
Brad
-Ernie White, my Dad
Waste vegetable oil as a fuel
Hi,
I am trying to help out one of my customers. He would like to know if he can run waste vegetable oil in his AFG beckett oil burner. Does anyone else know if this can be done. I have obviously told him all bets are off as far as manufacturer warranty goes as well as efficiency. Any advice would be appreciated.
Tim0 -
Not without extensive modifications. But some people have been successfull with 10% filtered veggie oil mixed in with #2.0 -
Veg oil in burner
I tried using pure bio-diesel in my AFG, to thick it wouldn't pump. I might try about 20% bio to no. 2 next time0 -
french fry vehicles
The people using veg oil to power cars and trucks have modifications done to the vehicle. One of the items added is the second tank for the veg oil. The motor is started adn warmed up on reg diesel fuel and then switch to the veg oil once the engine is warm, then switched back to regular fuel prior to shutting the engine off.
Thanks, Wayne0 -
french fry vehicles
Thanks, Wayne0 -
pump lubrication
The lubrication quality might affect the oil pump life??0 -
Lubrication is not a problem. Veggie oil lubricates a lot better than #2 fuel oil. The problem is the much higher viscosity and much higher flashpoint. The veggie oil needs to be heated to over 100 degrees before the pump for it to be thin enough to pump and to over 200 degrees between the pump and the nozzle to get it thin enough to atomize well. Even with the heating, the nozzle will usually plug up from varnish in under a week. The flame is also longer due to slower burning which can damage the back wall of the combustion chamber if it touches. There are ways around the problems but not easilly with conventional nozzles.0 -
Refer your customer to this site http://groups.yahoo.com/group/altfuelfurnace/
Bio deisel in oil burner
Hi Guys,
A friend of mine sent me this link and I've been enjoying the conversation. I did convert an oil burner for a friend to 100% bio deisel and did encounter these issues. The bio deisel is very corrosive and will harm the pump so I purchased a webster bio fuel pump and that worked well. I did have problems with the oil when it got cooler (the tank was outside) so I used a smaller tank right in the boiler room and it did make a big difference. The longest I had the boiler running was about three weeks on a beckett AFG burner and I noticed an accumulation of glycerin on the nozzle causing it to fail. I found that if you take the extra time in refining the oil (to remove as much glycerin as possible) when you make it makes the burn improve. The other things I was playing with was another way to preheat the oil because the nozzle line heater couldn't handle it and switching from a solid nozzle to a hollow did give me a better longer burn. I was impressed with the results, but it's a work in progress.0
- 129 Chimneys & Flues
