Gas boiler question
Paul Fredricks_3
Member Posts: 1,556
Thanks for the reply. It's been 2 years now that we've been talking about this. Figure it's time to get our ducks in a row.
Looking for advise
My brother in-law is thinking about replacing his atmospheric gas boiler as it's got to be 25 years old at least. Of course I'm the guy to do the job. I have done some gas in the past, but mostly work with oil fired equipment.
What I'm looking for are suggestions on what to put in. He has 3 heating zones, all baseboard. Currently he has a gas water heater, but we'd like to set up the new boiler so that we can drop in an indirect when the current one dies.
There is no radiant, just baseboard. I don't recall the BTU's, but I've got to figure around 110k. I will do a full heatloss to double check before going forward with anything. There are no plans to add on the house, no real need to.
As far as venting goes, there is the possibility of running direct vent and fresh air up the chimney, not sure about going out the basement wall yet.
I have looked at the Lochinvar offerings, both the Knight and the other one whose name escapes me at the moment. Any thought on these? Or any other thoughts.
I'd appreciate any info and opinions.
Thanks guys!0 -
gas boiler
There are a lot of good gas boilers out there. My best advice: Do the heat loss and connected load routine, decide on the best venting solution, then pick the boiler. A condensing gas boiler will be the best bet as far as efficiency is concerned, but may not fit your friend's budget. Pick the best boiler he can afford. My choices : Weil Ultra, Buderus and Viessmann.0
- 87.5K THE MAIN WALL
- 123 Chimneys & Flues
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
