Unico with Carrier Heat Pump
Jim Pompetti
Member Posts: 552
are set to factory specs. We do a ton of them this is the !st not to get a 35° coil
Unico system with Carrier Heat Pump
1 1/2 Unico system with a matching Carrier 13 seer heat pump 410A . Heat load is about 10kbtu's , air flow around 325 cfm's . Line sets insulated both (attic job) . We can only get a coil temperature of 42° F .Unico calls for around 35° f coil temperature . The subcooling is 12° . Any suggestions.0 -
Not in order
Overcharge unit,high humidity,too much airflow.
I'm seeing some of the newer equipment only running a 5 degree subcool temps.
Unico
Everything is set up to factory specs0 -
Try this
measure your suction line temps if its 18 to 20 degree below
return temps then she fine.Head to the next one.0 -
specs ?
Which factory ?? carrier or unico. I have been wondering how well the 13+ seer stuff was going to play with unico's. Might want to try wrapping up part of the condensor coil without pulling any of the charge out and see what happpens.0
