Munchkin metric screws, where to get
J. Cricket
Member Posts: 36
I'm only a homeowner, but I do know that I can buy metric screws at my hardware store. Let me explain the problem.
My Munchkin failed to start yesterday, I saw that it would light but then turn off after a second. I figured the flame sensor needed cleaning (and I was right). Unfortunately the people who had serviced the unit 2 years ago had stripped the heads of the screws holding the flame sensor. I took the screws off by hammering in a square bit, but of course I then needed new screws.
Unfortunately, they were 4mm x 8mm screws. A 6mm length is too short, 10mm is too long, no local hardware store had 8mm lengths. OK, so I cut a 10mm down to size. But the pan head is too big to fit on the left side; there is not enough space between the hole and the sensor opening. The original screws had an unusually small head.
OK, I sort-of-solved that too, by grinding down the sides of the screw head. But it wasn't pretty and will strip easily. This is stupid.
Where can I get 4mm x 8mm screws with a very small pan head?
Why was the Munchkin designed to use hard-to-find screws?
You could try
contacting HTP at their website and getting the proper ones, I would think they would drop them in an envelope and send to you.
http://www.htproducts.com/products/munchkin/
Dave0 -
bicycle or motorcycle shops
usually have small metric bolts with allen heads. They are generally small diameter heads.
hot rodBob "hot rod" Rohr
Living the hydronic dream0 -
That's a great thought Dave
but kinda $uck$ when you need it NOW0 -
It's kinda surprising, but...
... my local Ace Hardware has an interesting array of metric, imperial, etc. screws, stocked by Midwest Fastener. Home Despot also carries an array of MF-stocked screws to look through. You can always order them from McMaster Carr, I suppose.
As for the reason that they have metric screws, my guess is that it has to do with the European origin of most parts on that burner."Let me control you"
Lost in SOHO NYC and Balmy Whites Valley PA0
- 119 Chimneys & Flues
- 114 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
